1 members (Hanks custodian), 239 guests, and 11 robots.
Topics128,078
Posts1,056,027
Members48,433
I have a coolant leak in the front of the engine; radiator hoses & water pump look ok. I now want to check the freeze plugs, but don't know where all of them are located. Any help/diagram would be appreciated. Thanks.
In the front - there's one just over the timing cover and under the water pump.
<Front>
There's one on the back, top center.
<Back>
Two on the drivers side (mine has a block heater in one)
<Drivers Side>
If its leaking from the plug in the front - it should be fully exposed and quite visible to see.
