4 members (RoadsScholar, Mike Roache, moparguy, 51sub), 108 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
#856277 06/03/2012 8:30 PM
Is there a certain way to remove radio buttons from a 1950 3600.I nipped away at one of them and noticed the shaft is barbed.
I use a pair of side cutters and nibble at them until there is nothing left to prevent removal. Some brands of new buttons can be quite a challenge to install. Some of our members have soaked them in warm water before installation.
1951 1 Ton Completed
Thanks for the advice.I nipped away at the remaining four buttons and installed the new buttons.The new buttons went on quite well,just a little pressure pushing them on to the shaft.Thanks again for your time and help.
Quite often there is a hole in the barbed button 'blade' that accepts a small diameter drill bit or the like. This allows the buttons to be re-inserted without damaging the pushbutton mechanism. Simply insert the bit (stop) and push the button on hard.
Often there is a way to keep the blade fixed when prying the button off as well but it can be more difficult to find or access.
Larry
I would like to welcome Larry to the Stovebolt and to our forum here. Larry and his business partners restore and convert old auto radios.
Larry, maybe you could add a line to your profile and signature line so that we could link to your online page.
Cool! Welcome Larry. Where abouts are you in BC?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Welcome Larry!
Curious - what do you charge to rebuild an AD radio?
MrLang;
I am in the Mission area of BC.
Bigtonka;
Rebuilding costs vary depending on what one finds inside.
Drop me an email and we can talk.
Larry
Moderated by  truckernix
