2 members (TexasA&M48Truck, Wayne67vert), 77 guests, and 3 robots.
Topics128,212
Posts1,057,463
Members48,471
#846700 04/26/2012 3:29 AM
I have a 1951 Chevy 3100 5 window all original including 6 volt electrical system. In my infinite wisdom i purchased LED tail lights that are obviously 12 volt. Is there a 6 to 12 volt converter that i can install to get these to work or is there 6 volt LED tail lights i can purchase? Or should I just not travel at night.
Owner of a long awaited 1951 Chevy 3100 Pickup
Noonie #846724 04/26/2012 4:17 AM
Found these 6v LED. Most of the 12v LEDs will work on 6 volts they won't be as bright as if you had 12v running to it but it will be brighter than a 12v "standard" bulb and a bunch brighter that a 6v bulb. you might try it and see if you like it.
....David
Noonie #846879 04/26/2012 8:37 PM
Ex Hall Monitor
Ex Hall Monitor
The 6v LEDs I've found are little brighter than the incandescent bulbs they replace. There's a way to get 12v light out of your housing using available 6v bulbs. I submitted a tech tip to Ned that he's vetting now and should be up for review shortly. It's actually pretty simple. It involves putting a slight bend in the bulb bracket so you can run a #81 bulb for the tail light and an #1129 for the brake. The need for the bend is because the #1129 is much larger and won't clear the housing in the upper socket or the lens in the lower. The #81 is the same size as the stock #63 but twice the candle power.
#s 63 & 81 are on the left, #1129 second from right.
A direct side by side comparison of my 6v on left my modern 12v truck on the right.
Keep in mind that my modern truck has a mirrored reflector and my '38 6v is a much smaller housing and does not have a mirrored reflector.
Tiny #846905 04/26/2012 9:58 PM
I have a 52 Chevy 3100 that is still 6 volt. I purchased some LED tail lights from Classicparts.com:
(1947-53) LED Taillamp Assembly-Chrome-L-Plastic Red Len
Part # 49-121LR
They assured me these would work with 6 or 12 volts. But on my truck, the only way I could tell they were on was to put my eyeball up to the tail light. Then I discovered you can buy 6-to-12 volt converters. So I installed two of those (one for the brake light wire, and one for the tail light wire). That helped a lot. I got them from Jim Carter:
ITEM# DESCRIPTION QTY TOTAL
EL219 Volt Booster Negative Ground Conversion1 $89.50
My dad always told me, "Don't force it, get a bigger hammer".
Noonie #856687 06/05/2012 5:02 AM
Can incandescent bulbs fit into a LED light fixture?
I will be installing light fixtures into my office with LED bulbs...if i wanted to, can i replace the bulbs with incandescent ones?
LED Tubes led bulbs lights Dimmable LED Lights
Ex Hall Monitor
Ex Hall Monitor
On cars and trucks the LEDs are made to work in the old style incandescent sockets. I have no clue about structure fixtures. I'd recommend calling an electrician.
Tiny #856745 06/05/2012 2:01 PM
SPAM ALERT Tiny - note the links on that post
Flxible #856850 06/05/2012 10:03 PM
Ex Hall Monitor
Ex Hall Monitor
I didn't even notice the links until you mentioned them. I'll send a note to the mods.
Looks like someone beat me to it.
