4 members (Steelonsteel, FishinToms53, Gdads51, 1 invisible), 126 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#856660 06/05/2012 3:35 AM
MT
Offline
Bought a basket case 50 panel and now its time to try to get the front clip on and mounted. Problem is that someone hacked out the original frame and welded on a Camero front clip in. I have no clue where these originally went and what they held up? Any help would be appreciated.
http://i52.photobucket.com/albums/g23/metaltwister/Junk/CIMG0019.jpg
Change is Opportunity
MT #856670 06/05/2012 3:56 AM
They look like the front fender braces to me.They bolt to the lip of the front fender and then through the inner fender well to core support.
Tim
1951 3100 Chevrolet
MT #856671 06/05/2012 3:56 AM
Those are fender braces. They go under the fenders and bolt to the side of the radiator surround piece and then bolts to the underside/lip of the fender.
MT
Offline
thanks so much! I dont think the stock core support is going to be used so I will figure a way to modify them to work now that I know where they go... Thanks again.
MT #856825 06/05/2012 8:01 PM
...as I'm sure you know or can tell there is a left and right so "meausre twice cut once".
