9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | Bought a basket case 50 panel and now its time to try to get the front clip on and mounted. Problem is that someone hacked out the original frame and welded on a Camero front clip in. I have no clue where these originally went and what they held up? Any help would be appreciated. http://i52.photobucket.com/albums/g23/metaltwister/Junk/CIMG0019.jpg
Change is Opportunity
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | They look like the front fender braces to me.They bolt to the lip of the front fender and then through the inner fender well to core support.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Those are fender braces. They go under the fenders and bolt to the side of the radiator surround piece and then bolts to the underside/lip of the fender. | | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | thanks so much! I dont think the stock core support is going to be used so I will figure a way to modify them to work now that I know where they go... Thanks again.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...as I'm sure you know or can tell there is a left and right so "meausre twice cut once". | | |
