| | | Forums66 Topics128,022 Posts1,055,378 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85641 04/25/2004 6:20 PM | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | I have a couple fuel level gauges from 47-53 trucks and while installing one I found that the sender wire post is connected to ground (like the gauge housing). Is this correct? I would think it would never change it's reading from the fuel sender. I tested another and it didn't do this. I figured the first one was bad until I read that the GMC might be different?
'53 Chevy truck 1/2 ton
#85642 04/26/2004 3:05 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | The post shouldn't be connected to ground. Replace it with one that shows a change in resistance when the float arm is moved through it's travel and you should be set.
Joe
