| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 58 | Is there a certain way to remove radio buttons from a 1950 3600.I nipped away at one of them and noticed the shaft is barbed. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use a pair of side cutters and nibble at them until there is nothing left to prevent removal. Some brands of new buttons can be quite a challenge to install. Some of our members have soaked them in warm water before installation. | | | | | Joined: Apr 2011 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 58 | Thanks for the advice.I nipped away at the remaining four buttons and installed the new buttons.The new buttons went on quite well,just a little pressure pushing them on to the shaft.Thanks again for your time and help. | | | | | Joined: May 2012 Posts: 2 New Guy | | New Guy Joined: May 2012 Posts: 2 | Quite often there is a hole in the barbed button 'blade' that accepts a small diameter drill bit or the like. This allows the buttons to be re-inserted without damaging the pushbutton mechanism. Simply insert the bit (stop) and push the button on hard.
Often there is a way to keep the blade fixed when prying the button off as well but it can be more difficult to find or access.
Larry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would like to welcome Larry to the Stovebolt and to our forum here. Larry and his business partners restore and convert old auto radios.
Larry, maybe you could add a line to your profile and signature line so that we could link to your online page. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Cool! Welcome Larry. Where abouts are you in BC? | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Welcome Larry!
Curious - what do you charge to rebuild an AD radio? | | | | | Joined: May 2012 Posts: 2 New Guy | | New Guy Joined: May 2012 Posts: 2 | MrLang; I am in the Mission area of BC.
Bigtonka; Rebuilding costs vary depending on what one finds inside. Drop me an email and we can talk.
Larry | | |
