3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#855990 06/02/2012 6:11 PM
Hi bolters, my 63 has some bad rust inside the cab. Like right above the doors and the eyebrow piece above my front windshield. Any suggestions on getting it gone? I would make some panels for it but i just dont know where i would start for the pieces above the door. I would put pictures up but i dont know how to. Thx
Chance #856084 06/03/2012 3:02 AM
IMHO, rust above the windshield and the door jambs, is the proverbial, "kiss of death". The problem with rust in thease areas, is not the rust-thru, but the rust you can not see. The best method to eradicate the rust, is to remove the top, by drilling out the spot-welds around the perimeter drip rail, followed by removal of the top cap. By doing so, you can address the rust issues, that have not manifested itself as actual rust-thru.
If the floor boards, kick panels, rockers, cab corners, A-pillars & cab supports are rust, as well, you may be better off finding a donor cab.
I would need some help with that if i did. The rust on mine is bad. The floor boards, rockers, cab corners are BAD, and the eyebrow piece is bad too. I found a 64 full complete truck for 400 bucks. I hope i can get it.
Chance #856425 06/04/2012 4:51 AM
Keep in mind, the '60-'63 Chevy/GMC truck cabs, are different than the 4-5-6 Chevy/GMC truck cabs, so the doors & dash components will be different. Also, the '60-'62 frames are a different width that the '63-'66 cabs, so you will need to do some modifications to the supports, where the bolts drop through the floor and into the frame-to-cab perches.
