8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible), 103 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#85594 05/05/2003 5:07 AM
Finally got around to checking the wiper motor that came out of my '56 3600. It's the electric type (was that stock in '56? I thought it should have had the vacume type) and doesn't work. So I took it apart. Wow!! not exactly a electro-mechanical nightmare, but pretty interesting how they made things work back then. The motor tests (continuity)OK and the gearing apears to work OK, so I'm going to take the burnishing file to the contacts and put it back together.
Does anyone have any insight into these old 'lectric types??
Thanks in advance.
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
#85595 05/05/2003 2:23 PM
ya lucked out! cool the electric wipers were optional in the task force trucks, w/ the vacuum unit being the most common by far - should be able to bench test it easy, and the only problem I've ever found is w/ the switch and the cable-knob mechanism - watch for bad connections and blown fuse . . .
