1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | I plan to install the outside sun visor on my '56 tomorrow. I'm a bit apprehensive about drilling into my cab, but it has to be done if i want this...
i am looking for tips, etc, that any TF Stovebolters may have for making this as easy as possible - and more importantly - less likely for me to screw up.
Can it be done with one person (just me)? Ideas for templating? What should go between the visor and body? I was planning to use strip caulk Anything else i didn't think of?
thanks for any input
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | no one has installed a visor on a TF? i postponed my install on the hopes that i get some advice... | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thanks for the reply, Tiny. this is the part: outside sun visor it looks like this installed: visor on truck tom | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I can't help but I'm sure someone can. Good luck.
