1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Almost impossible to get to seal. What are my choices? Should I replace the intake too?
H Online: Content
The automotive machine shop where I worked part time for several years had a BIG belt sander, with a belt over a foot wide and a bed four feet long. It came in very handy for flattening out warped manifolds and other parts that needed to have gasket surfaces trued up over a wide area. It's been debated several times whether to leave the intake and exhaust bolted together during such a procedure. I prefer to loosen the bolts slightly to let the manifolds find their closest common plane, then hit the belt sander with the complete assembly.
Riding in the Passing Lane
The 292 engine exhaust runs so hot it warps the manifolds all out of shape & cracked. Its best to find a good used one from a 230 or 250. They are usually good.
1972 Chevy c10 Cheyenne Super
1 Offline
Always machine the 2 manifolds while bolted together,(like Hot Rod Lincon said), bolt them together down on flat surface,and then tighten the bolts. If resurfaced separate from each other, they will be out of plane, and will always leak. (Several past experiences taught me this lesson).
The older I get, I only want to work on older rigs.
This thing has been machined so many times until there is little left. If I salvage one from a 250 will i need the intake too?
Its best to keep them together unless you see signs of leakeage between them. You have to watch for the throttle linkage. There are variations in them. The early exhaust flange had 2 studs & the later ones had 3. You can use either if you changa the flange on the pipe.
0
0 Offline
I'm installing a new Chinese A/M 292 exhaust manifold...(crude I might add) & snuggly attached the intake..with unit on a bench, I ran a straight edge along the assy. This takes the guess work out....
