| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | My new modern style wiring kit arrived and my first query is where to put the fuse panel? EZ Wiring suggest the driver side kick panel, but I'm not so sure I like it there. The glove box is another choice, but I think I would really like to make some kind of a hinged or drop down panel to mount it on. Anybody ever do that? Any other suggestions? It will go in a '51 3100 cab.
Drew
| | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I just finished installing a fuse block in my '55 1st series. It is located on the drivers side inside firewall. All the fuses are within reach and yet out of sight. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks for the info. I am just concerned about any clearance issues. This AD has the foot parking brake peddle close to the side panel, but maybe your idea would work for me. I'll give it a look. Thanks.
Drew
| | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I mounted my EZ wiring fuse block on the driver side kick panel. And I have no problem getting to it or clearance issues. You can use one of the holes that mounted your old panel there. Just be sure not to mount the fuse block upside down. The cover identifies where each fuse goes and the cover can go on either way ask me how I know | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks for the additional info. On short notice headed to NSRA event in York,PA, so now won't get to this project until Monday.Thanks again.
Drew
