8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | I have a 1959 235 ci motor in my 1952 3100 p/u. The motor came out of a car. If that fact makes any difference, I don't know. I used the 216 water pump, adaptor and pulley. The pulley on the water pump matches the crankshaft pulley (harmonic balencer) as far as belt width is concerned. I believe it is a 5/8" belt. I then changed the 12v gen. pulley to a 5/8" (it was the small one, 3/8") to match the other two. Now I can't find the belt to match. Does anyone know a Advance Auto, o'reilly's or Auto Zone part # that will give me the correct belt? AND i THOUGHT GETTING THE BELT WOULD BE THE EASY PART!!! HA!!!
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Take a piece of rope or wire or something and go around the pulleys to check the length. Then go to a tractor store and give them the length you need. Make sure you tell them you want the 5/8 width belt. Some call it a 5L belt. When I measure with a rope/wire I always make sure to space it up to take in consideration of the width of the belt. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | 10-4 I took the 3/8 belt to an o'reily's and he tried to match it with a 5/8 belt. He only had belts the went from 3/8 to 3/4. No 5/8 at all. That's why I was questioning myself about the 5/8" width. That is what it measures.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You need a better parts store. Try a NAPA or maybe a tractor parts place. Lots of the old tractors ran 5/8 belts.
Find an old parts store. One that's been in business for many years. They should be able to find you a belt.
Many of the newer stores can't do much if it isn't on their computers. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Ran into the same problem. Local NAPA has all their belts hanging in the showroom. You can compare them yourself.
Drew
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Just some numbers for you for the correct 5/8" belt: Dayco-23425 Goodyear-24423
Hope that helps! | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Thanks those are the #'s I am looking for.
