1 members (Otto Skorzeny), 85 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#855032 05/29/2012 10:22 PM
So has anyone here attempted this swap into their Bolt? I've got everything bolted together and in place in my 46 2-ton Chevy. I bought a B&M control box to operate the converter lock-up. Now it's time to tackle the dreaded TV Cable. So has anyone here successfully got this swap to work in their Bolt? It seems the best/easiest solution is to fab/weld a bell-crank to the bottom of the throttle pivot located on the side of the manifold. I know there is specific geometry that needs to be adhered to but I can work that out once I get the basic foundation in place. Just wondered what has worked (and failed) for other members attempting this combo. Thanks in advance for anyone's input.
not specific to your engine, but these might help you think about it all:
http://www.cpttransmission.com/tech_tvcable.htm
http://www.tvmadeez.com/article/index.html
