3 members (tclederman, TUTS 59, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | I continue work, ever so slowly, on my 57 3100. Years back I picked up a differential in great condition out of a 59 suburban that was used as a small school bus. I will install it in the 57, which I am restoring to 'near' original. Its been opened up, checked out, some bearings replaced, new passenger side axle and then cleaned up & painted. I noticed recently, that the (factory installed) brake 'tee' bracket is on the drivers side (Left) on the diff housing, as opposed to all others I've seen, which are on the passengers side (Right) side. Am now wondering if burb's are set up that way or, if somehow I ended up with an 'odd ogg'? Any help would be appreciated. delky WY
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the majority I've seen were on the driver side, but there was variation, possibly depending on the plant the truck was assembled or the year, and with the T on the other side, some of the brake line routing was different as well ... no problem, just adapt to the difference or change it to suit the rest
Bill | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | In the 'for what it is worth' department. Maybe I just had a revelation in this one. I am often slow on the uptake, but it appears to me that 55.2 thru 57 brake line from mc to rear end were on the passengers side of frame, whereas (at least some) 58 and 59 brake line to rear end were on the drivers side. Anyone have any more info on that to share? delky dave WY
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the assembly manual [which is from 55] does show it on the pass side for all 31xx models, although I think that might have varied at different assembly plants, and no telling if the spec changed anytime after 55/56
Bill | | |
