6 members (SWEET, rfs56trk, sron48, 78buckshot, Wickedbass, JW51), 58 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#85483 10/30/2002 4:58 PM
Started having problems keeping the battery charged up and losing headlights on a couple of my last trips. Put the battery on a trickle charger and had the generator tested and rebuilt. Reinstalled everything but still not seeing any positive results on the guage. When I tap on the regulator I see the guage jump to the charge side in time with my tapping. Do I need a new regulator? I read through the manual last night but really didn't find a black and white answer.
Deaner
1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
#85484 10/31/2002 1:51 AM
Try cleaning the terminals on the voltage regulator. A little rust can screw them up. Check the mounting screws of the regulator also it needs a good ground to work. Remember to disconnect the battery first the red wire is live. You don't need a fire.
if it dosen't need fixed, break it
#85485 10/31/2002 2:42 PM
When I had charging problems on my 50, I took both the generato wink r and volt regulater off and to the electrical shop and had them tested. Cost $5.00 to find out the volt reg was bad. Most older shops can do this.
#85486 11/24/2002 3:29 PM
All good avice. I cleaned up all of the connections/terminals and still nothing. The educated test results were that the regulator had shorted out. So a new one has been installed. Never new those 6 volt headlight could be so bright. grin
Deaner
