| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85483 10/30/2002 4:58 PM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | Started having problems keeping the battery charged up and losing headlights on a couple of my last trips. Put the battery on a trickle charger and had the generator tested and rebuilt. Reinstalled everything but still not seeing any positive results on the guage. When I tap on the regulator I see the guage jump to the charge side in time with my tapping. Do I need a new regulator? I read through the manual last night but really didn't find a black and white answer.
Deaner 1950 Chevy 3600 Stake Bed
I don't know where I'm going, but there's no sense being late!
#85484 10/31/2002 1:51 AM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Try cleaning the terminals on the voltage regulator. A little rust can screw them up. Check the mounting screws of the regulator also it needs a good ground to work. Remember to disconnect the battery first the red wire is live. You don't need a fire.
if it dosen't need fixed, break it
#85485 10/31/2002 2:42 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | When I had charging problems on my 50, I took both the generato  r and volt regulater off and to the electrical shop and had them tested. Cost $5.00 to find out the volt reg was bad. Most older shops can do this. | | |
#85486 11/24/2002 3:29 PM | Joined: Jul 2000 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 30 | All good avice. I cleaned up all of the connections/terminals and still nothing. The educated test results were that the regulator had shorted out. So a new one has been installed. Never new those 6 volt headlight could be so bright.
