7 members (kades51, Forty9, Peggy M, greenie-reddy, ShopRag, Bill Hanlon, 1 invisible),
88
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | *Admin* If this belongs in paint - I apologize * I've got my Filling Station paint by PPG in front of me - the formula sticker they put on covers all the instructions for applying. So I hit up the website to see if there were special instructions - drying time etc.... First thing I notice is that they talk about adding DXR80 hardener... http://www.tcpglobal.com/docs/ppgdarp.pdfI haven't seen mention of this on this forum thus far. Proceeding w/o the hardener unless someone advises me otherwise. Lonnie? Thanks, Mark
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Yes, you need to use the hardener or it will not dry. According to the tech sheet,the mixing ratio is 8 to 3 to 1. 8 parts color, 3 parts reducer & 1 part hardener.
You should be able to find the correct hardener & reducer at any autobody supplier who carries PPG products.
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks Jeff - guess I'm not painting tomorrow... bah. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Due to "VOC" limitations the vender in Ottawa has stopped selling acrylic paint. Theyre all urethane paints, with urethane reducers.
Anyone ever mix? | | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | Enamel will dry without the hardener, but it takes up to 30 days for the oxidation process to happen. Hardener speeds up the process to 3-5 days. If enamel with no hardener is subjected to any sort of polishing procedure before the binder oxidizes, the paint rolls up in big chunks instead of smoothing out.
Lacquer paint is simply pigment and solvent, without an oxidizing binder, and can be polished and/or color-sanded as soon as the solvent dries out, usually 12 hours or less. Alkyd enamel, acrylic, and the most recent synthetic paint, urethane, requires at least a few days of drying/oxidizing time before any sort of finishing process is attempted. Jerry
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Jerry - there should be an iPhone app named the Hotrod App - I would ask it a question and it would provide an answer instantly.
At $1 an app - you would make a killing! | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Looks great!
Did you mix or reduce the paint?
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks! Yes, I used a urethane reducer and universal hardener. (4, 1, 1 as per the tech sheet when using urethane reducers instead of acrylic) 3 light coats, it went on very evenly, I'm very happy with it!
