0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | can somebody tell me what or if there are any 5 lug hubs from early cars to fit the front of my 46 1/2ton to change it over from 6 lug? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you stay with Huck brakes you need 1949-50 passenger car hubs and drums. If you change over to Bendix brakes you need 1951-54.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | so if i find a 51-54 chevy car drums, they'll fit? or do I have to change the spindles too? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i wanna change to bendix brakes too
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Your spindles will work fine. The only change in the spindles, when Chev went to Bendix, was to increase the size of the two bottom bolt holes. You will need backing plates from a 1951-59 1/2 ton.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Someone will hopefully correct me if I'm wrong but I believe you can use all the "stuff" from a '51-'54 donor car: backing plates, bolts, spacers, hubs, and drums. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have never used passenger car backing plates for this conversion. I know the trucks will work. My parts book shows different backing plates for pass and truck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | so I have to look for 51-59 1/2 ton hubs, drums, and backing plates...is that correct? just trying to get it straight before i go trudging thru the mud at the junkyards here, its been raining alot
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | OR if i stay with the huck brakes and get the 49-50 hubs and drums do I need to change the backing plates or can I keep my old ones?? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If going with Bendix you need 1951-59 1/2 ton backing plates and 1951-54 pass hubs and drums. If staying with Huck then you only need the 1949-50 hubs and drums, you use your old backing plates.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | You can use the car backing plates, but you have to drill a hole for the bottom mount to mount the backing plate to the two bottom holes on the spindle knuckle. If you do, you can use a large washer to cover the car holes in the backing plate, since they are close to the holes you will drill, and that will cover and seal the original car holes.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
