Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Woogeroo, Tronman, Youngin' Tut 59, WarEagle1, PullG), 152 guests, and 3 robots.
Topics128,288
Posts1,058,579
Members48,492
#854233 05/26/2012 2:52 PM
can somebody tell me what or if there are any 5 lug hubs from early cars to fit the front of my 46 1/2ton to change it over from 6 lug?
hoozat #854238 05/26/2012 3:57 PM
If you stay with Huck brakes you need 1949-50 passenger car hubs and drums. If you change over to Bendix brakes you need 1951-54.
My Blog
Pre '68 Dave #854240 05/26/2012 4:02 PM
so if i find a 51-54 chevy car drums, they'll fit? or do I have to change the spindles too?
hoozat #854241 05/26/2012 4:04 PM
i wanna change to bendix brakes too
hoozat #854253 05/26/2012 5:15 PM
Your spindles will work fine.
The only change in the spindles, when Chev went to Bendix, was to increase the size of the two bottom bolt holes.
You will need backing plates from a 1951-59 1/2 ton.
My Blog
Pre '68 Dave #854260 05/26/2012 5:38 PM
Someone will hopefully correct me if I'm wrong but I believe you can use all the "stuff" from a '51-'54 donor car: backing plates, bolts, spacers, hubs, and drums.
waldo53 #854264 05/26/2012 6:10 PM
I have never used passenger car backing plates for this conversion.
I know the trucks will work.
My parts book shows different backing plates for pass and truck.
My Blog
Pre '68 Dave #854401 05/27/2012 11:57 AM
so I have to look for 51-59 1/2 ton hubs, drums, and backing plates...is that correct? just trying to get it straight before i go trudging thru the mud at the junkyards here, its been raining alot
hoozat #854419 05/27/2012 2:03 PM
OR if i stay with the huck brakes and get the 49-50 hubs and drums do I need to change the backing plates or can I keep my old ones??
hoozat #854440 05/27/2012 3:45 PM
If going with Bendix you need 1951-59 1/2 ton backing plates and 1951-54 pass hubs and drums.
If staying with Huck then you only need the 1949-50 hubs and drums, you use your old backing plates.
My Blog
Pre '68 Dave #854450 05/27/2012 4:41 PM
You can use the car backing plates, but you have to drill a hole for the bottom mount to mount the backing plate to the two bottom holes on the spindle knuckle. If you do, you can use a large washer to cover the car holes in the backing plate, since they are close to the holes you will drill, and that will cover and seal the original car holes.
