| | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 58 | Hello! I'm getting into the research for the wiring on my 1936 1.5 ton truck. I keep reading about the headlight terminal blocks, but the best description given for the location is "inner fender". I've looked, and mine must be missing. My light wiring was snipped just shy of the light itself, so no wiring to trace back. The most logical place for terminal blocks, to me, would be somewhere inside the radiator shell. Any help would be appreciated on this! Thanks! | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Jeff, I can't help with your situation but I can offer that the terminal blocks for my '46 headlights is on the inner fender adjacent the headlight. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | My 38 did not have any terminal blocks for the head lights. | | | | | Joined: Aug 2010 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 58 | Thanks guys! I assume that the purpose of a termainl block is mainly in case you had to replace or repair the light/bucket. Also, hope all had a good Memorial Day weekend. Thanks to all the Vets! | | |
