| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Does anyone know where to get the old rear rubber floor matting used in the Burbs and wagons rear? Jim Carter doesn't sell it. Eric | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have looked long and hard for that stuff for my panel. I finally bought the narrower rubber locally, easy to find up to 4' wide but not 5' wide. I glued the seam, not ideal but acceptable to me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Eric, What year? From 47-55, the rear floor cover in GM Suburbans was glued-on linoleum. Panel trucks did not come with a GM floor mat/cover. The floor is 54 inches wide - brown linoleum (as used from 47-53; black in 54/55) is available in the correct thickness. It has to be cut-to-fit and grooved, if you are interested in original appearance. http://www.battleshiplinoleum.com/ | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Panel trucks did not come with a GM floor mat/cover. That's odd my, '48 1 ton Panel/Bus had the brown linoleum glued to the floor when I got it & had the holes through floor & you could see the indentations on the floor where the bus seats sat on both sides went.....joe I agree with Tim, the panels did not come stock from the factory with matting or linoleum on the rear floor, suburbans came with linoleum. Joe, your panel is a conversion and was used for hauling kids, I would bet that having linoleum was a requirement from the school contract. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Joe,
I agree with George. The non-GM aftermarket conversion of a panel truck into an ambulance, or into a crew truck, etc, most likely had a different floor cover.
| | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | Thank so much guys. The one I'm working on is a 54 Suburban so I need black right now. I have a wagon so its gonna need brown. Where can I buy each of em? Eric | | |
