1 members (moparguy), 98 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
#854081 05/25/2012 8:30 PM
Does anyone know where to get the old rear rubber floor matting used in the Burbs and wagons rear? Jim Carter doesn't sell it.
Eric
Leo Offline
Moderator
Moderator
I have looked long and hard for that stuff for my panel. I finally bought the narrower rubber locally, easy to find up to 4' wide but not 5' wide. I glued the seam, not ideal but acceptable to me.
Eric,
What year?
From 47-55, the rear floor cover in GM Suburbans was glued-on linoleum. Panel trucks did not come with a GM floor mat/cover.
The floor is 54 inches wide - brown linoleum (as used from 47-53; black in 54/55) is available in the correct thickness. It has to be cut-to-fit and grooved, if you are interested in original appearance.
http://www.battleshiplinoleum.com/
That's odd my, '48 1 ton Panel/Bus had the brown linoleum glued to the floor when I got it & had the holes through floor & you could see the indentations on the floor where the bus seats sat on both sides went.....joe
I agree with Tim, the panels did not come stock from the factory with matting or linoleum on the rear floor, suburbans came with linoleum. Joe, your panel is a conversion and was used for hauling kids, I would bet that having linoleum was a requirement from the school contract.
Joe,
I agree with George. The non-GM aftermarket conversion of a panel truck into an ambulance, or into a crew truck, etc, most likely had a different floor cover.
Thank so much guys. The one I'm working on is a 54 Suburban so I need black right now. I have a wagon so its gonna need brown. Where can I buy each of em?
Eric
