2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | I was thinking about using a frame rail mount tank on my '46 half ton, but trying to use the stock filler location. I was going to have a tube made to go from the stock filler under the seat towards the tank and then a flexible hose to take into account the motion of the cab in relation to the tank. I don't want a bed filler as I plan on using the truck for hauling once in a while, and may need to refill while hauling.
Is this madness? Will it work? Is it safe?
Thanks!
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | you would probably have to move the filler neck further up the cab for gravity reasons, im thinking that might be all you need to do, | | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | Vickraft,
I might give that a try. Where did you get your tank?
Thanks! | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | http://www.tanksinc.com/index.cfm/page/ptype=results_w/mode=specials/results_w.htmThis was a clearance Item I got from this Company about a year & a half ago. They sell Stainless or regular metal. Check them out I'm sure they can help. Good luck. Let me know if you have any more questions. This wasn't hard to do, and I expecially like the stock look from the outside. | | | | | Joined: Sep 2002 Posts: 153 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 153 | I just completed the install similar to vickraft with a Tanks Inc universal tank U1-GH except substituted the 2 inch filler tube with a 2.25 filler. Add the 60 degree elbow and it comes up through the floor of the cab behind the seat. I had a muffler shop make me an extension of the filler tube.
I made brackets to strap the tank up between the frame and the drive shaft. I used a stock filler tube that came off a stock tank through a hole in the floor behind the seat into the tank. I also made an access hole for the sending unit and fuel line.
BigErn I will attempt to email or PM some pictures to you. 1946 Chevy Half Ton ('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS) 1976 Margay Panther X, MC91B | | |
