| | | Forums66 Topics128,157 Posts1,056,885 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | Does anyone know if the 48 1/2 ton pickup came with a 4 speed on the floor as an option? Or were they all 3 speeds on the column? | | | | | Joined: Nov 2011 Posts: 12 New Guy | | New Guy Joined: Nov 2011 Posts: 12 | I had a 48 way back in the early 80s. It had a four on the floor, although I always took off in second. Pretty sure it was original. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A four speed transmission was a Regular Production Option on all 1/2 ton Advance-Design trucks (1947-1955). Standard equipment on 1/2 ton trucks was the 3-speed (shifter on the floor in 1947 and shifter on the column all other years).
Last edited by tclederman; 05/26/2012 2:35 AM. Reason: edited errors as noted by Tom
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Tim, it's hard to tell what you meant in your response. By "1.2 ton trucks" did you mean to say "1/2 ton trucks" or "1(to)2 ton trucks?"
I'm pretty sure the '48's were three-on-the-tree. Mine is, as are all the other '48 half tons I've seen. The '47's were floor shifts, and they went to the column shift in '48.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I won't blame that on the drink but I'll blame it on the silly iPad 3-screen keyboard.
I will edit the post above (I am now at a real computer).
| | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | | | | | | Joined: Jun 2009 Posts: 803 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 803 | My '48 Chevy 1/2 ton is an original 4-speed on-the-floor. That was an available option. I rarely use the "granny gear"--starting out in 2nd gear most times. | | |
