1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#853964 05/25/2012 7:16 AM
Does anyone know if the 48 1/2 ton pickup came with a 4 speed on the floor as an option? Or were they all 3 speeds on the column?
I had a 48 way back in the early 80s. It had a four on the floor, although I always took off in second. Pretty sure it was original.
A four speed transmission was a Regular Production Option on all 1/2 ton Advance-Design trucks (1947-1955). Standard equipment on 1/2 ton trucks was the 3-speed (shifter on the floor in 1947 and shifter on the column all other years).
Last edited by tclederman; 05/26/2012 2:35 AM. Reason: edited errors as noted by Tom
Tim, it's hard to tell what you meant in your response. By "1.2 ton trucks" did you mean to say "1/2 ton trucks" or "1(to)2 ton trucks?"
I'm pretty sure the '48's were three-on-the-tree. Mine is, as are all the other '48 half tons I've seen. The '47's were floor shifts, and they went to the column shift in '48.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I won't blame that on the drink but I'll blame it on the silly iPad 3-screen keyboard.
I will edit the post above (I am now at a real computer).
Thanks for the info!
My '48 Chevy 1/2 ton is an original 4-speed on-the-floor. That was an available option. I rarely use the "granny gear"--starting out in 2nd gear most times.
