1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#853601 05/24/2012 12:24 AM
I have a 55 2nd that has a 350 engine. It currently has the chicken leg engine mounts in the front of the engine and the bellhousing mounts in the rear. I would like to remove the front mounts to be able to mount the alternator down low to give a cleaner engine compartment. Which of the replacement mounts would be the best?
http://www.ecklerstrucks.com/chevy-truck-tubular-engine-mount-crossmember-v8-1947-1959.html
http://www.speedwaymotors.com/Chevy-to-1955-1959-Chevy-Pickup-Motor-Mounts,8473.html
What are the advantages and disadvantages of each. Also, can I keep the bellhousing mounts or should I remove them and switch to a transmission crossmember? Thanks in advance.
I believe the type from Ecklers [which all the vendors carry, shop for price] will give you a stronger setup, adding a full cross member - also might be less interference with the e-brake mechanism .... and you don't need the trans cross member unless you go to an automatic
Flxible #853647 05/24/2012 3:02 AM
Chassis Engineering recommends a crossmember-style front engine mount for frames wider that 25 inches (link). Your TF frame is 34 inches wide. The crossmember style mount will help to avoid frame twisting.
regards,
Leon
Leon #853672 05/24/2012 4:03 AM
I used a tubular style mount to fit a 455 Buick in my panel truck.
I modified a tube mount that was for a 460 Ford in a F100 truck!
It allowed a nice low, set back & I was able to use the stock cast iron
exhaust manifolds, too.
As the others here have stated ... it adds a bit of additional stiffness to the frame; esp. when putting in one of these torque monsters.
