1 members (Nick in Manitou),
159
8
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 19 New Guy | | New Guy Joined: Mar 2012 Posts: 19 | Got rear wheels off of ground, start with shifter at neutral, rear wheels turn. Which linkage needs adjusting? That Pertronix unit I installed works as advertised. Jimbar
1953 Chevy 3100 3 window
1997 VW Rialta Motorhome 2011 Fusion
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1954 Chevrolet truck Hydra-Matic transmission 1954 Servicing the Chevrolet Truck Hydra-Matic Transmission - Part 1 - Maintenance and Adjustments Have you disconnected and re-connected the linkage? If not, you might get by with just a few adjustments. I'd start with the adjustment at the bottom of this page - special tools are needed for earlier adjustments in this booklet. NOTE: this adjustment is quite sensitive - change it just a little for large differences in shift-points. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If the wheels turning when jacked up is your only concern, don't adjust anything. That's not uncommon, due to the fluid transmitting a little torque when the weight of the vehicle isn't on the wheels. It was pretty common for the vehicle to lurch forward a little on cold startup. Once the fluid warms up, the forward creep in neutral goes away. The 1-2 shift point on a Hydramatic happens almost as soon as the vehicle starts moving, maybe 5-8 MPH. This is also normal. Since it has a fluid coupling, not a torque converter, a very low-ratio 1st. gear was required for good performance when pulling away from a stop. The shifts are very firm, also. It's better to have a firm shift- - - -a mushy, slippy shift wears out clutches in a hurry. Jerry
| | | | | Joined: Mar 2012 Posts: 19 New Guy | | New Guy Joined: Mar 2012 Posts: 19 | No, I never did take the linkage loose anywhere except the carburetor. As a matter of fact, I think it ran a little better when I set the emergency brake and stopped the wheels. Maybe my imagination due to being jet engine deaf. Thanks. Jimbar
