6 members (TexasJim50, stlcardinalsguy, Woodcmiami, klhansen, Hanks custodian, Wally / Montana), 64 guests, and 2 robots.
Topics128,059
Posts1,055,820
#85342 01/05/2004 10:41 PM
Hey gang (Yeah its me again), I upgraded from a six volt voltage regulator to a new twelve volt (YAHOO!). In the instructions it suggested that I connect the battery and then put a jumper between two of the terminals to set the voltage regulator. Has anyone ever heard of or done this? Should I disconnect my newly rebuilt 12 volt generator first?
Thanks for the great help and advice!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver
1929 **** Model A Pickup - Restoration
#85343 01/06/2004 3:38 AM
Follow the instructions, you must polarize the regulator before starting the engine.
#85344 01/06/2004 9:18 PM
It is correct. Follow the directons for your GM system, Fruds are different on which wires are touched just so you know
