| | | Forums66 Topics128,051 Posts1,055,730 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85342 01/05/2004 10:41 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Hey gang (Yeah its me again), I upgraded from a six volt voltage regulator to a new twelve volt (YAHOO!). In the instructions it suggested that I connect the battery and then put a jumper between two of the terminals to set the voltage regulator. Has anyone ever heard of or done this? Should I disconnect my newly rebuilt 12 volt generator first?
Thanks for the great help and advice!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#85343 01/06/2004 3:38 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Follow the instructions, you must polarize the regulator before starting the engine. | | |
#85344 01/06/2004 9:18 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | It is correct. Follow the directons for your GM system, Fruds are different on which wires are touched just so you know
