6 members (GMCJammer51, Greg_H, NorCal52Suburban, Hush, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
#852184 05/17/2012 8:18 PM
Were oil filters standard or an option in 1946. My COE has a filter mounted on the firewall but it isn't hooked up. I was thinking about leaving it that way. If the truck sees 100 miles per year I'd be surprised.
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
optional until the V8's
Jrpontiac #852223 05/17/2012 11:23 PM
my 46 has it on the firewall too and it is bypassed also, trying to find out which line goes inot it and which one comes out, does it look like this http://s629.photobucket.com/albums/uu14/kurtdh519/oil%20filter/
Jrpontiac #852240 05/18/2012 12:41 AM
I just added a photo of my system. They were aftermarket and mine was on the firewall too. I have a 1/2 ton 46. The company that rebuilt my engine warned me to make sure the oil line is restricted becuase you will loose pressure to the rocker arms. The trucks were not designed for the filters. I used 1/8 copper lines. I am worried they will plug. Time will tell.
GWWirth #852260 05/18/2012 1:55 AM
Jason,
Take a look at this Tech Tip:
http://www.stovebolt.com/techtips/engines/oil%20filters/index.html
I believe you have the S-2 filter. See Image 17 & 18.
Instruction Sheets are at the end of the page.
Here is the S-2:
http://www.stovebolt.com/techtips/engines/oil%20filters/inst8.jpg
Good luck with your truck.
Harold
Harold
I have a full pressure 235 (1954), my filter is an s2. If I have a full pressure system would I still need to restrict it. Just wondering. I still think I'm going to leave it without but good to know if I hook it up at a later date.
Jason
1946 GMC COE
Jrpontiac #852320 05/18/2012 10:23 AM
If you have the normal 1954 lubrication system (that has not been converted to full flow), you would use a by-pass oil filter. No additional restriction is necessary if you you an AC S2 by-pass oil filter.
tclederman #852324 05/18/2012 11:23 AM
even though they only filter a small percentage of the oil, they do take out an incredible amount of junk. It wouldn't hurt to hook it up.
GWWirth #853382 05/23/2012 1:08 AM
the filter setup i have doesnt have a line going to the top of the tank, both my lines go thru the bottom of the tank,now which line on the motor goes in the middle and which goes on the outside?off the motor
hoozat #853420 05/23/2012 3:17 AM
I believe the return (to motor) comes out of the middle opening in your filter There should be a plug in the side of the motor for this. One of the other 2 holes is for the input from the pump where your oil pressure gauge is connected. There has to be a "T" installed to accommodate both lines (one to the filter & one to the gauge). The other opening on your filter is for a threaded plug so you can drain & clean the filter when you change oil.
Take a good look at this & you will see how the oil flows into the filter canister, through the filter element, into the center tube and out the filter canister back into the motor.
Harold
Harold
GWWirth #855047 05/29/2012 11:21 PM
dam! you and I have almost the exact same truck! they almost look the same color (mines all apart at the moment tho,)heres my pics ..
