3 members (78buckshot, WingWright, Rusty Rod), 43 guests, and 1 robot.
Topics128,050
Posts1,055,643
#852970 05/21/2012 4:02 AM
In working on my cab the solder joint on the cab seam has failed. Partly due to an accident and rust. See the pictures. The was I see it I can blast of the rust and 1. re solder it ( I have never done this) 2. use body filler 3. cut it out and weld in a patch panel. Any suggestions?
See the pictures.
https://picasaweb.google.com/106094054066011607454/CabSeam#
Brimmer #853007 05/21/2012 1:06 PM
(1)Melt out all the remaining lead with a plumbers torch. Do not sand or grind the lead because of lung issues.
(2) sand blast the rusty area, then wash with Dupont #3812 enamel reducer.
(3) Fill the area with a fiberglass based body filler. "MarGlass" by Evercoat is one to consider.
(4) Top coat with regular body filler if required.
(5) Prime the area with Dupont Variprime etching primer, then spray with 2K high Build primer or whatever other product you like to use.
wbrowne #853011 05/21/2012 1:19 PM
I don't know, but it seems to me that even though there is some rust, there has not been much metal lost. If so then find someone that can show you-or do it for you- how to re-lead the area.
....David
wbrowne #853099 05/21/2012 11:25 PM
Perfect, exactly what I was looking for. Thanks for the tip.
Brimmer
Brimmer #853140 05/22/2012 2:22 AM
I saw Eastwoods has a lead-free solder kit.
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
