3 members (tclederman, 2 invisible),
51
Mod | | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | http://www.classicparts.com/Arms-Blades/products/50/Geting ready to install windshield wipers on my 51 pickup. Got 10" replacement blades from Cassic Parts. Noticed that my original arms have no clips to attache the blades? Anyone have a picture or or info on this? Its been 6 years since I removed them and can't remember how they were attached? I checked my manuals and couldn't find any details. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I assume you're talking about this blade. If so there should be a slot in the end of the arm for the hook in the blade to fit in.
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | http://i150.photobucketYes that is the wiper blade I have. From the explanaion on how to connect it to the arm, it would appear that I may not have the right arm? | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know which is the 'right' arm for a '51 but the arm you have is not for that blade (or vice/versa).
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Looked through my spare parts and did manage to find another set of blades that are much shorter and the proper clip is on the end. They line up good and fit my 10" aftermarket wiper blade. Mystory solved. Thanks for the imput. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If you are not an original fanatic try out marine blades and arms. They are mainly stainless and come in a variety of sizes. Also read somewhere that MGB wipers are the same. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | If you are not an original fanatic try out marine blades and arms. They are mainly stainless and come in a variety of sizes. Also read somewhere that MGB wipers are the same. I've got an MGB out in the barn. I'll check out the blades/arms this weekend. | | |
