Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#852706 05/19/2012 10:44 PM
what is the sockit size on the master cylinder on a 47-54 pickup ?? can any buddy help me out ?
care to chat write back
mickster #852743 05/20/2012 1:50 AM
I have a 58 3100 and mine is sort of rounded off but I used a 4 way lug wrench to take mine on and off. Give it a try.
mickster #852764 05/20/2012 3:39 AM
Are you referring to the big nut that retains the piston and spring assembly? I believe it's 1 3/8". A flat-ended punch against a corner of the nut and a vigorous whack with a BFH is the way we loosened that nut back when I was making a living working on them. We virtually never removed a master cylinder to rebuild it, just change out the internals with the M/C mounted on the frame!
Hotrod Lincoln #853212 05/22/2012 11:06 AM
cool ill give it a try
mickster #853279 05/22/2012 6:19 PM
Jerry, that explains the cut in the nut on my master cylinder. Thought it was from a pipe wrench. Never would've guessed a punch.
Ed
Forty9 #853502 05/23/2012 5:15 PM
Crusing in the Passing Lane
Perhaps you are referring to the filler cap-could be 8 point, use a large Cresent wrench,(they make metric ones now) etc., or find the correct size, measure across the flats, count the flats, remember, you, or someone else(your kid) might have to do this in the future, rounded off fasteners don't help the issue.
EdPruss #853594 05/23/2012 11:53 PM
How many of these master cylinders have you rebuilt?
For the filler caps,a faucet wrench works pretty nice. If it's so tight you bugger it up removing it,it needed replacement anyway. I use an O-ring instead of a gasket so it only has to be finger-tight to seal.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
speed 6351 #854607 05/28/2012 8:51 AM
Ive always used Jerrys method for re-building them in the vehicle.
For the top filler nut, a crescent wrench on end, with a screwdriver stuch thru the hole and ,,,,twist.
