| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 24 New Guy | | New Guy Joined: Apr 2012 Posts: 24 | Anyone ever use bedliner on there frame? Im really afraid that it would hold in moister. Anyone have any tips or ideas about it? Thx | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I haven't used it, but I'm not sure why you're afraid it will hold in moisture? As long as you do your prep properly there should be no moisture trapped under it, and if there was an issue with bedliner taking in moisture after being applied, most modern trucks would have their beds rusting off from the inside out. This isn't an issue.
Having said that, what are you trying to gain by applying bedliner to the chassis? I think you're better off with chassis paint with good prep. | | | | | Joined: Apr 2012 Posts: 24 New Guy | | New Guy Joined: Apr 2012 Posts: 24 | I have the bedliner handy and the paint in my opinion wont protect the frame from getting scratch, etc. Bedliner is strong and can last a while if its done right. | | |
