2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#852416 05/18/2012 9:59 PM
Anyone ever use bedliner on there frame? Im really afraid that it would hold in moister. Anyone have any tips or ideas about it? Thx
I haven't used it, but I'm not sure why you're afraid it will hold in moisture? As long as you do your prep properly there should be no moisture trapped under it, and if there was an issue with bedliner taking in moisture after being applied, most modern trucks would have their beds rusting off from the inside out. This isn't an issue.
Having said that, what are you trying to gain by applying bedliner to the chassis? I think you're better off with chassis paint with good prep.
My 46 GMC on Photobucket
I have the bedliner handy and the paint in my opinion wont protect the frame from getting scratch, etc. Bedliner is strong and can last a while if its done right.
