8 members (Guitplayer, klhansen, fonz8261, cmayna, Lightholder's Dad, Hotrod Lincoln, RLB, 52Carl),
87
Mod | | | Forums66 Topics128,192 Posts1,057,229 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85235 07/14/2002 9:17 PM | | Anonymous Unregistered | | Anonymous Unregistered | Anyone have a Delco Remy part # book?? I am trying to identify F-201 part# 1972009 & F-200 part# 1972002 | | |
#85236 07/14/2002 9:43 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What kind of parts are these? I may be able to identify what they go to if i know what area to look as per part category
#85237 07/14/2002 11:58 PM | | Anonymous Unregistered | | Anonymous Unregistered | They are points condenser units. Mechainiac, did you get my email on the Napco stuff? | | |
#85238 07/15/2002 8:11 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | All I can come up wit from my sources so far is that it fits GM(imagine that). Yes, I recieved the pics.Is there a part number just inside the ring gear teeth on the bolt flange or on the end of the pinion gear?
#85239 07/20/2002 8:49 PM | | Anonymous Unregistered | | Anonymous Unregistered | I found a source to decode these numbers. They are replacement parts for F**d. | | |
#85240 07/22/2002 12:32 AM | Joined: Mar 2001 Posts: 12 Member | | Member Joined: Mar 2001 Posts: 12 | At least they're still GM parts. Also a proven fact that it takes GM parts to make a F**d run. Ha! Seriously, now that they are identified, you can sell them accordingly on the F**d sites. Have fun and good luck. | | |
#85241 11/04/2006 1:12 PM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mothertrucker, where did you find a source to decode these Delco numbers?? Could the rest of us accesss the source?? Denny Graham Sandwich, IL
Denny G Sandwich, IL
#85242 11/04/2006 2:42 PM | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Denny, Mothertrucker is no longer on the site. Here's one of his Gallery pages . His email address may still be good. Otherwise, try a Google search. He sells parts so I'm sure he'll come up. Peggy (using John's log-in  )
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
