6 members (panic, J Lucas, Gray_Ghost, 2-Ton, UtahYork, 55shaker), 73 guests, and 4 robots.
Topics128,187
Posts1,057,212
Members48,465
Anonymous
Unregistered
Anonymous
Unregistered
Anyone have a Delco Remy part # book??
I am trying to identify F-201 part# 1972009
& F-200 part# 1972002
What kind of parts are these?
I may be able to identify what they go to if i know what area to look as per part category
Anonymous
Unregistered
Anonymous
Unregistered
They are points condenser units. Mechainiac, did you get my email on the Napco stuff?
All I can come up wit from my sources so far is that it fits GM(imagine that).
Yes, I recieved the pics.Is there a part number just inside the ring gear teeth on the bolt flange or on the end of the pinion gear?
Anonymous
Unregistered
Anonymous
Unregistered
I found a source to decode these numbers. They are replacement parts for F**d.
At least they're still GM parts. Also a proven fact that it takes GM parts to make a F**d run. Ha! Seriously, now that they are identified, you can sell them accordingly on the F**d sites. Have fun and good luck.
Mothertrucker, where did you find a source to decode these Delco numbers?? Could the rest of us accesss the source??
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
24601
24601
Denny,
Mothertrucker is no longer on the site. Here's one of his Gallery pages . His email address may still be good. Otherwise, try a Google search. He sells parts so I'm sure he'll come up.
Peggy
(using John's log-in grin )
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
