2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | Were oil filters standard or an option in 1946. My COE has a filter mounted on the firewall but it isn't hooked up. I was thinking about leaving it that way. If the truck sees 100 miles per year I'd be surprised. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | optional until the V8's
Bill | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I just added a photo of my system. They were aftermarket and mine was on the firewall too. I have a 1/2 ton 46. The company that rebuilt my engine warned me to make sure the oil line is restricted becuase you will loose pressure to the rocker arms. The trucks were not designed for the filters. I used 1/8 copper lines. I am worried they will plug. Time will tell. | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I have a full pressure 235 (1954), my filter is an s2. If I have a full pressure system would I still need to restrict it. Just wondering. I still think I'm going to leave it without but good to know if I hook it up at a later date. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you have the normal 1954 lubrication system (that has not been converted to full flow), you would use a by-pass oil filter. No additional restriction is necessary if you you an AC S2 by-pass oil filter.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | even though they only filter a small percentage of the oil, they do take out an incredible amount of junk. It wouldn't hurt to hook it up. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | the filter setup i have doesnt have a line going to the top of the tank, both my lines go thru the bottom of the tank,now which line on the motor goes in the middle and which goes on the outside?off the motor | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I believe the return (to motor) comes out of the middle opening in your filter There should be a plug in the side of the motor for this. One of the other 2 holes is for the input from the pump where your oil pressure gauge is connected. There has to be a "T" installed to accommodate both lines (one to the filter & one to the gauge). The other opening on your filter is for a threaded plug so you can drain & clean the filter when you change oil. Take a good look at this & you will see how the oil flows into the filter canister, through the filter element, into the center tube and out the filter canister back into the motor. http://www.stovebolt.com/techtips/engines/oil%20filters/inst8.jpgHarold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | dam! you and I have almost the exact same truck! they almost look the same color (mines all apart at the moment tho,)heres my pics .. http://s629.photobucket.com/albums/uu14/kurtdh519/ | | |
