4 members (HandyAndy, David Bush, joe apple, 3B), 70 guests, and 1 robot.
Topics128,050
Posts1,055,753
#851485 05/14/2012 7:04 PM
Anyone have suggestions for a particular brand of polyurethane for the bed wood.
Number of coats to use ? did you do the underside as well?
Thanks, Paul
Minwax /Helmsman.4 coats on underside and sides,5 on top.It's been on 4 yrs with no problems.I did mark the floor in one small spot.The repair leveled out nicely
thanks I will look for that brand.
The key is to put the same number of coats on the bottom as the top, or at least close to the same number. The ends are where the wood will soak up the most moisture and over time this is where the finish failure will happen. So, build the finish up on the ends either by brushing on 6-8 coats or just stand the boards up in a 1/4" or so of finish over night and the the next day flip the boards for the other end. Put the final coat once the holes are drilled. The Helmsmen Spar Varnish is good stuff. I've had it on my Model A bed for 8+ years and it looks brand new.
....David
Look at Mar-k's website. They did quite a series of test to see which finish held up the best.
Also, look at the Bed Forum right here. It helped me a lot.
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
V
V Offline
wodniw5
My approach was to use the varnish that is made to be outside in the weather. Known as Marine Spar Varnish, this is the stuff they put on wooden boats. Creates a very hard & durable finish.
6 to 8 coats is what the boatbuilders put on them.
Not sure how poly would hold up over the years compared to Spar?
Just a thought. Anyone else ever use Spar Varnish finish?
UV resistant marine spar varnish is what seemed to be the best from what I gathered.
You Tube
thanks, all
I second that, here is a link to the bed I just finished using the Minwax Helmsman
[IMG]http://inlinethumb55.webshots.com/50806/2782006850107361323S600x600Q85.jpg[/IMG]
