Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (ShopRag, farmallb, jasrking, TUTS 59), 34 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#851880 05/16/2012 12:27 PM
Maybe I'm being a little too picky - but which way do the spark plug washers go? Noticed each side of the washers has a different diameter (never noticed that before!). Does the larger surface of washer go against the head?
tcox #851900 05/16/2012 1:56 PM
I put the larger diameter towards the plug. I'm not sure why but I don't recall any problems over the years. I'm sure other bolters will chime in too.
SimS
SimS #851903 05/16/2012 2:28 PM
i put them in that way too. it made more sense to me that way.
tomctomc #851905 05/16/2012 2:31 PM
Ex Hall Monitor
Ex Hall Monitor
How are they on the plug when you remove them from the box? I never noticed a different diameter either but I'd assume they way they were put on at the factory is the way they need to be installed. Anyway that's the way I've always done it & never had an issue arise.
Tiny #851908 05/16/2012 2:38 PM
The gasket is actually a "crush washer". It's there to transfer heat as well as to seal pressure. I've been putting the flat side (larger diameter) toward the plug for 50+ years. It was explained to me that the radiused side is supposed to flatten and conform to the shape of the sealing surface of the head, and should be crushed about halfway by the tightening force, not flattened out completely.
Hotrod Lincoln #851997 05/16/2012 10:23 PM
Thanks for the replies - the washers were not on the plugs (AC Delco R45), just loose in the box. Just happen to notice the difference and got to wondering which way is correct.
tcox #853602 05/24/2012 12:25 AM
Jerry is right. The radiused side compensates for an uneven surface. You see a lot of crush washers on aircraft engines. However on an aircraft engine they are only used once.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
