| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Maybe I'm being a little too picky - but which way do the spark plug washers go? Noticed each side of the washers has a different diameter (never noticed that before!). Does the larger surface of washer go against the head? | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | I put the larger diameter towards the plug. I'm not sure why but I don't recall any problems over the years. I'm sure other bolters will chime in too.
SimS | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i put them in that way too. it made more sense to me that way. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | How are they on the plug when you remove them from the box? I never noticed a different diameter either but I'd assume they way they were put on at the factory is the way they need to be installed. Anyway that's the way I've always done it & never had an issue arise.
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The gasket is actually a "crush washer". It's there to transfer heat as well as to seal pressure. I've been putting the flat side (larger diameter) toward the plug for 50+ years. It was explained to me that the radiused side is supposed to flatten and conform to the shape of the sealing surface of the head, and should be crushed about halfway by the tightening force, not flattened out completely. Jerry
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Thanks for the replies - the washers were not on the plugs (AC Delco R45), just loose in the box. Just happen to notice the difference and got to wondering which way is correct. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Jerry is right. The radiused side compensates for an uneven surface. You see a lot of crush washers on aircraft engines. However on an aircraft engine they are only used once. | | |
