1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Order a new one. It's cheap and you won't pull your hair out trying to fix the old one.
| | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Just checked out Classic parts, didn't realize ya could buy just the needle. Never changed one before. Any tricks?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Just checked out Classic parts, didn't realize ya could buy just the needle. Never changed one before. Any tricks? Yes, the trick is to realize the needles they advertise are just a cover, not the whole needle. You need to use your old hub and a stub of the old needle. Chuck | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | And, be careful when you pull the old needle hub off the shaft so you dont break the shaft. | | | | | Joined: Apr 2012 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2012 Posts: 23 | I just broke the shaft on a 55.1 speedo. what a shame. thought I was being carefull, but when it breaks, it snaps, not a lot of warning. It would not lift off, trying to work a redo of the numbers. To do it over again, I would have left it on and worked around it.
1955 1st Series 1/2 ton
