2 members (dwreills, Otto Skorzeny), 79 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
Ok. So I am gonna install a 3 wire 12Si on my chevy 235. It is internaly regulated. Do I need to remove to black box (old external Regulator) on the fire wall?
If so How would I go about this. Any tips would be great.
Thanks Folks
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Ex Hall Monitor
Ex Hall Monitor
I converted my '38 to a one wire 6v alternator. I left my old voltage regulator in the firewall for aesthetic reasons. I moved the heavy wire that ran from the generator to the 'gen' tab on the regulator to the 'bat' tab. That way the ammeter displays correctly but the mechanical regulator isn't in the loop. I don't know which wire on a 3 wire feeds back to the battery but you could connect it to the 'bat' tab & leave your old regulator if you so desire.
3B Offline
Hy GrandpasTruck, you don't "have" to remove the regulator, but you will have to deal with the wiring that is attached to it. Depending on how you want to wire the alternator into the truck, you can repurpose some of that wiring, hope that helps.
Ok. thanks guys. I found what I needed on a google search and from your help. Thanks a lot folks
My YouTube:
Hey GrandpasTruck, see http://s1109.photobucket.com/albums...uff/?action=view&current=alt158a.jpg for how I do it. When you think in terms of new wiring instead of patching into an old system it seems easier. Never scrimp on wire sizes!.
Also, feel free to poke around in my other 'bucket albums as well.
best wishes,
Les
