| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I searched for the answer to this question but I got 1000 answers to everything but what I asked. I want to know where to connect the 2 ground straps on a 46 pup.
b51r
b51r
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | which 2 ground straps? there should be one from the battery, either to the cab or the frame or the engine, and all of those should be grounded together .... battery > cab > engine > frame is one way .... a starter bolt is a good place on the engine
Bill | | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | there is supposed to be 2 ground straps one for the the battery and another one. where does he second one attach? b51r
b51r
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've never seen one come from the factory with more than one, the one from the battery.
| | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | One to the starter mounting bolt and one to the frame.Believe its because engine is rubber mounted. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The position of the ground straps isn't particularly important, but if you're using the original-type flat braided ground straps, there should be one from the battery to the frame, and another from the frame to the engine block. Some folks run a longer ground cable directly from the battery to the engine block in the bellhousing area to get the lowest-resistance path for starter current. For 6 volt applications, the cables need to be BIG, #0 or larger. A smaller-diameter ground wire, or sometimes more than one, should connect the frame to the cab and/or bed to provide a good ground path for lights and accessories. These are particularly important on older vehicles with rust issues between body parts. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | More than one must be a 'new' thing. My '38 only has one, from the battery to the tranny.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | On my 51, the battery is grounded to the frame and the engine is grounded to the frame with a braided strap. Is that the answer to your question? | | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | my 46 has two ground straps thanks to Hotrod Lincoln for answer.
b51r
b51r
