3 members (Nick in Manitou, TexasA&M48Truck, Hotrod Lincoln), 191 guests, and 2 robots.
Topics128,082
Posts1,055,964
Members48,430
#851260 05/13/2012 4:49 PM
I searched for the answer to this question but I got 1000 answers to everything but what I asked. I want to know where to connect the 2 ground straps on a 46 pup.
b51r
b51r
which 2 ground straps? there should be one from the battery, either to the cab or the frame or the engine, and all of those should be grounded together .... battery > cab > engine > frame is one way .... a starter bolt is a good place on the engine
there is supposed to be 2 ground straps one for the the battery and another one. where does he second one attach?
b51r
b51r
Ex Hall Monitor
Ex Hall Monitor
I've never seen one come from the factory with more than one, the one from the battery.
One to the starter mounting bolt and one to the frame.Believe its because engine is rubber mounted.
H Online: Content
The position of the ground straps isn't particularly important, but if you're using the original-type flat braided ground straps, there should be one from the battery to the frame, and another from the frame to the engine block. Some folks run a longer ground cable directly from the battery to the engine block in the bellhousing area to get the lowest-resistance path for starter current. For 6 volt applications, the cables need to be BIG, #0 or larger. A smaller-diameter ground wire, or sometimes more than one, should connect the frame to the cab and/or bed to provide a good ground path for lights and accessories. These are particularly important on older vehicles with rust issues between body parts.
Ex Hall Monitor
Ex Hall Monitor
More than one must be a 'new' thing. My '38 only has one, from the battery to the tranny.
On my 51, the battery is grounded to the frame and the engine is grounded to the frame with a braided strap. Is that the answer to your question?
1951 1 Ton Completed
my 46 has two ground straps thanks to Hotrod Lincoln for answer.
b51r
b51r
