3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#851122 05/13/2012 2:44 AM
got my truck running today, and took it for a ride up the street, and it quit running,sounds like it is out of gas when i try to start it it kicks over then shuts off, any body know what the problem could be? seems like as soon as it warmed up it shut down
hoozat #851124 05/13/2012 2:46 AM
can you provide more info?
year truck?
engine?
DADS50 #851236 05/13/2012 3:06 PM
1946 1/2 ton, 216 motor,just got it running and changed to open drive from torque tube, still original 6 volt, its getting gas to the carb, im hoping its not electrical
hoozat #851241 05/13/2012 3:25 PM
I had exactly the same problem with my 46 about two weeks ago, I found that my vacuum wiper motor was bleeding all the vacuum from the motor. I plugged the vacuum line and it runs fine. I never drive it in the rain anyway.
oh? that may be the problem, my vacuum line is wide open at the manifold because I ripped out the vacuum wipers and have an electric setup now, i'll try that and see what happens
hoozat #851523 05/14/2012 10:52 PM
found the problem.......major rust in the gas tank, it clogged up the petcock and the fuel filter on my engine......needless to say, I have to find another gas tank for my 46 1/2ton
