2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | got my truck running today, and took it for a ride up the street, and it quit running,sounds like it is out of gas when i try to start it it kicks over then shuts off, any body know what the problem could be? seems like as soon as it warmed up it shut down | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | can you provide more info?
year truck?
engine? | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | 1946 1/2 ton, 216 motor,just got it running and changed to open drive from torque tube, still original 6 volt, its getting gas to the carb, im hoping its not electrical | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I had exactly the same problem with my 46 about two weeks ago, I found that my vacuum wiper motor was bleeding all the vacuum from the motor. I plugged the vacuum line and it runs fine. I never drive it in the rain anyway. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | oh? that may be the problem, my vacuum line is wide open at the manifold because I ripped out the vacuum wipers and have an electric setup now, i'll try that and see what happens | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | found the problem.......major rust in the gas tank, it clogged up the petcock and the fuel filter on my engine......needless to say, I have to find another gas tank for my 46 1/2ton | | |
