0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I plan to install an old 12v radio I have laying around in my '51 suburban. Looking for a source for antennas. A mast type is fine. Hopefully one that will fit the hole in the cowl where the old one was....
Anyone know of a place selling antennas?
Kurt | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hi Kurt - I bought one from Jim Carter for $16.00 < CLICK >It's a nice looking antenna for the price. He has others available at higher prices. It looked pretty good in the hole in my cowl that a previous owner had cut (on the passenger side instead of the correct location on the drivers side.) At least it looked good until I raised the hood. The hood bent it back. The PO had drilled it too close to the hood opening.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | All the old truck vendors sell a repro antenna for the AD truck. I have one on my 51. Mine is stainless and made of very thin metal but it does the job. It should come with a proper template for drilling the hole. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Lonnie,
Thanks. I guess it comes with the cable and plug to connect to the radio?
Kurt | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes it does come with that. thelocation is quite critical to avoid interference with the hood. There is also a bracket that attaches to the inside sheet metal to support the base. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Yes Kurt -
Tim is correct. Cable, plug, and bracket come with the antenna. The base pivots to allow it to mount on an angled surface.
If the hole is already in your cowl, loosely mount the antenna and slowly raise the hood before locking it in place. The previous owner may have screwed up the location. If you are going to cut the hole, a pattern for the location is in '54 Truck Accessories Manual. May be one available for your truck, too. As Tim noted, the location of the hole is critical.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Lonnie, Tim, thanks. I will check the existing hole. There was an antenna in there when I got the truck in 1973. Seems to me that the hood did touch the antenna when it was open, but I'll check tomorrow. There is a 6 volt AM radio (VW) in the truck now, but it hasn't worked in many years. I have a 12 V. AM/FM radio of the same size that I thought I might try. I'm also working on a way to get 12V. More on that later.
Kurt | | |
