0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,441
Members48,443
#85138 05/07/2002 4:01 AM
Hi all, I am in the process of doing a lot of work to the cab of my 59 1/2 ton. The wipers have never
worked very well, but here in the Desert, it doesnt matter that much. Anyway, I took the motor out to clean
and lube it, install new arm bushings etc.
Questions: Did GM offer a single speed wiper motor (electric) in 59? My switch has continuity to ground in one
position only, and there only seems to be 2 positions for the switch instead of the 3 I would expect with a 2 speed
wiper. The switch looks factory, the wiring plug fits ok and so on. This makes me think it is the original switch.
Next: Am I correct in assuming the switch is the ground for the wiper motor? I only get a complete circuit when I test from
the power wire to the switch body.
Any insight appreciated
Can't say for sure on '59, but I had a bottom of line '64 GMC that only had a single speed wiper motor. smile
